Problem with php 5.6 hosting provider
Thread began 10/11/2016 7:26 am by Jonas | Last modified 10/13/2016 11:48 am by Ray Borduin | 975 views | 4 replies |
Jonas
My hosting provider has recently changed the php version on the server to version 5.6.
This causes some problems with the website that is created with WebAssist.
Partly so, the image database is empty (the window is white), and partly it's obviously something wrong with the contact side (according hosting provider).
It is very possible that there are a lot of other errors that I do not see or know. How do I do now! Desperate because the page is now up and going on the new server.
I attach a log that might help.
There is no log attached. It shouldn't have issues on that php version. If you give me a url to reproduce and FTP access I can debug it and let you know what is going on.
Jonas
Oh, but let's see if you can find the problem / problems.
The problem seems to be that the server doesn't have PEAR installed, which is required for the file manager to work properly.
I replaced the file manager with a different file manager. It seems to work but occasionally it has an error:
Forbidden
You don't have permission to access /webassist/kcfinder/browse.php on this server.
Talk to your hosting provider. See if they can either install PEAR on the server, or if they can fix the intermittent 403 error.
Jonas
Thanks for the quick feedback. My hosting provider will fix this.
