error your SQL syntax
Thread began 10/10/2016 1:21 pm by malcolm230194 | Last modified 10/11/2016 3:05 pm by Ray Borduin | 1551 views | 6 replies |
malcolm230194
The following code is generated by eCart. and crashes with 'You have an error in your SQL sytax. It has affected two sites that were previously working. They both crashed after templates were updated containing changes in unrelated code.
The page is an order confirmation and runs perfectly if this section is commented out, though obvoiusly doesn't do what was intended.
Another problem with this is that it will only run on the local server as root even thouigh the user a/c is valid and tested in MySQL Workbench. This is a serious reputational and financial problem and I would appreciate your early attention
You will also see in the attached code some hacks going round in circles with session variables to try to save the order number correctly. I gave up trying to do it by the book as I got nowhere and every saved order had the number 400007. Christ only knows where that came from but it consistently appeared. Pragmatism overuled purity.
I'm in your hands.
Malcolm
You have this on line 118:
$ConditionalQuery->bindColumn("OrderType", "d", "K", "WA_DEFAULT");
That means that you have the data type set to numeric, but have set the value to "K"... that is incompatible and will cause a syntax error.
What is the data type of the OrderType column in your database? That row should probably either be:
$ConditionalQuery->bindColumn("OrderType", "s", "K", "WA_DEFAULT");
or:
$ConditionalQuery->bindColumn("OrderType", "d", "1", "WA_DEFAULT");
malcolm230194
eCart and or MySQLi is generating corrupt code
Good morning Ray
Firstly the data type error was an oversight in my attempt to recreate the page and not the problem.
The problem lies in the store cart details generated by eCart. By commenting out everything else I'm left with this code which generates your error message from line 124 in rsobj.php.
$ReplaceConnection = $store_i;
$ReplaceTable = "order_detail";
$ReplaceQuery = new WA_MySQLi_Query($ReplaceConnection);
$ReplaceQuery->Action = "delete";
$ReplaceQuery->Table = $ReplaceTable;
$ReplaceQuery->addFilter("DetailOrderID", "=", "d", "".$_SESSION['OrderID'] ."");
$ReplaceQuery->execute();
Please treat this as a matter of urgency as these are live sites that have stopped working. I've put test site information in the private message.
I've attached the file again for you to see
I've also experienced the following error when trying to add or edit another recordset on the same page. Test is fine after setting up the query but trying to save it gives the following message.
'error while executing applyServerBehaviour in MySQLiRecoredset.htm, a javascript error occurred'
I've done the usual of clearing the Dreamweaver cache but it doesn't change.
malcolm230194
PS
This post has been deleted.
It looks like you have your Store cart summary and store cart details server behaviors set with a trigger "before page load", but the inserts refer to posted form values.
Update the two server behaviors to use "any form post" as the trigger instead... but that isn't the problem.
In order to find out your actual error I turned debug mode on in the queryobj.php file. That shows the true error instead of the general error when an action fails. The real error is:
DELETE command denied to user 'xxxxxxx'@'localhost' for table 'order_detail'
This means that your database user doesn't have the correct permissions to allow a delete from the order_detail table. You can fix the problem by going into the database and updating the user permissions to allow delete on that table.
malcolm230194
Thank you
Thanks for your prompt reply Ray. You're a life saver.
One problem that is still unsolved though is why I can't add or change another dataset when the eCart server behavious are on the page. Any ideas?
Best regards
Malcolm
The broken eCart Object server behavior seems to be preventing the recordset update from working. I think if you add this code just above the doctype tag it will fix the eCart Object, and that would also fix the Recordset issue.
// WA eCart Redirect
if ($eCart1->redirStr != "")     {
header("Location: ".$eCart1->redirStr);
I've also attached a file that would prevent the error even with a broken eCart server behavior. You can replace it in your user configuration folder in this location:
Configuration/ServerBehaviors/PHP_MySQL/WebAssist/MySQLi/FieldTypes.js
FieldTypes.js
