login working after changing php.ini
i changed php.ini completely then suddenly all login stopped working.
then i realised the php.ini contained some folder which didnt exist. after upload on live server i get errors like this: Warning: Unknown: open(/Applications/XAMPP/xamppfiles/temp//sess_becb17d73546d49b1dafd7f980075038, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/Applications/XAMPP/xamppfiles/temp/) in Unknown on line 0
I removed php.ini page also changed it to just:
ini_set("post_max_size", "30M");
ini_set("upload_max_filesize", "30M");
ini_set("memory_limit", -1 );
Still getting error & can login.
Please help
