File permissions for Power CMS Builder on localhost
Thread began 10/09/2016 3:34 pm by mjon67244103 | Last modified 10/20/2016 6:31 pm by Ray Borduin | 505 views | 6 replies |
mjon67244103
I am using PowerCMS Builder on Mac OS 10.10.5, using Dreamweaver CC 2015.2. As a testing server I am using MAMP Pro 4.0.5, with Apache 2.2.31 and MySQL 5.6.28.
I've been using the video tutorial at https://www.youtube.com/watch?v=tGUP3-BnVfU as a guide. I'm trying to add a CMS to an existing site.
I create a database using phpMyAdmin, and can define it in PowerCMS Builder, but the Server Diagnostic Check always fails with File Permissions.
I have checked permissions for the directory that contains the site folder on the testing server, using phpMyAdmin. I have checked permissions using the File Access Permissions tab in DW. I have checked permissions using Finder Get Info.
I have checked numerous forum articles regarding this problem but can't get past it.
Thanks in advance for your assistance!
Can I see a screen shot of the error as well as the folder get info window? That should be all that you need to adjust.
mjon67244103
Screen shots
Attached are screen shots of file info and error message. Thank you!
In your getInfo "everyone" has "read only" access... change that to "Read & Write" and see if that fixes the problem.
mjon67244103
No go
Thanks for your response, Ray. I changed the "everyone" access to Read & Write - same result: File Permissions error
Did you make the change for the root folder for the site as well as the /Connections folder? Are you putting the files right in the root or a sub-directory? Maybe try a sub-directory... you may have better control of the permissions outside of the root.
mjon67244103
Yes, changing the permissions using File Info specifically for the Connections folder did the trick. Thanks for your help, Ray!
