Warning: Cannot modify header information - headers already sent by (output started at /Users/....
Thread began 10/03/2016 6:52 pm by mrs | Last modified 10/03/2016 7:47 pm by Ray Borduin | 475 views | 1 replies |
mrs
I've got one of these common issues...
Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /Users/mrsmail/Sites/pedalbritain/Connections/PowerCMSConnection.php on line 9
Warning: Cannot modify header information - headers already sent by (output started at /Users/user/Sites/site/Connections/PowerCMSConnection.php:9) in /Users/user/Sites/site/admin_cms/tbl_bikeimg_insert.php on line 70
I've been through and removed any spaces outside of the PHP tags that are above the DOCTYPE, actually, I've removed all PHP tags here apart from one opening one and a closing one. I don't know what's going on.
Can you advise?
I've attached the file in question.
Thanks.
Turn off deprecated messages in your php.ini file. The Cannot modify header error is caused by the display of the deprecated message. If you turn it off the error will go away as well.
