trying follow Create Double Opt Registration SDystem cannot get past Create Pages, The choices I get are Dynamic MySQL Connection and Dynamin MySWLi Connection. Neither one makes a connection.
Thread began 10/03/2016 2:50 pm by Larry Olsen | Last modified 10/03/2016 7:44 pm by Ray Borduin | 791 views | 2 replies |
Larry Olsen
After I define a connection all I show in the connection choices is None.
Dreamweaver can sometimes fail to recognize connections. I'll need more information to determine exactly why this happens.
Does the connection show from the Window->Databases panel?
Is the page you have opened saved into the same site as the connection file and named with a .php extension?
Have you tried closing and opening Dreamweaver to force it to refresh?
Can you successfully test the connection?
Have you installed the "Database and Server Behaviors" extension from the Adobe store?
Larry Olsen
Solved!!!
I did not have the Database and Server Behaviors installed. I downloaded it and it all works the way it should now. Thanks for the speedy reply.
