Sort not working
I have done this many times and it is not working now so I'm wondering if something has changed. Clicking on column headers does nothing.
http://dev.rsavvy.com/order_search.php
I'd need to see a copy of the page to diagnose why the code might not work.
You already have an ORDER BY in your recordset select statement. You can set the default sort in the sort server behavior to set the initial sort.
OK but removing it does nothing. I know I just did. Still doesn't sort but clicking the column headers
Can I get a url to reproduce and FTP access? I'll debug it and figure out why it isn't working.
Details in private. Be sure to use SFTP or you won't get in
You still had an ORDER BY in your recordset. I removed it and the sort works now.
