Framework issue
Thread began 9/23/2016 12:28 pm by Mike Perry | Last modified 9/26/2016 1:03 pm by Ray Borduin | 195 views | 3 replies |
Mike Perry
Framework issue
Trying to insert a Plugin into a dwt.php file. The Wizard adds the following into the top of the template file:
<?php require_once('../webassist/framework/framework.php'); ?>
<?php<wasscdeletetemp>?><?php require_once('../webassist/framework/library.php'); ?>
<?php<wasscdeletetemp>?> creates a syntax error. The wizard runs fine in a non-template file. . .
Running DW CS6, Windows 10 Anniversary Update. All Extensions have just been reinstalled
Help??
Mike
Try deleting your filecache .dat file. There should be code that automatically removes the <wasscdeletetemp> and the empty tags that contain them, but that code clearly isn't running properly.
Does it work on regular php pages? I imagine it doesn't have anything to do with the template itself.
Mike Perry
That fixed it. . FYI, it worked fine an a non-template file. . .
Thanks Ray -- have you been able to make any progress on the updates accommodating MySQLi changes? Know you're up to your shoulders in alligators trying to drain the swamp. . .
I'm working on it and making progress. Thanks for the understanding.
