Update page not updating record
Thread began 9/13/2016 2:29 pm by iain331081 | Last modified 9/14/2016 9:57 am by Ray Borduin | 2555 views | 7 replies |
iain331081
I'm sure this must be something dumb, but I can't see what I'm missing with the attached update page - basically isn't updating the record.
Have attached it below. If you can have a quick look that would be much appreciated. Thanks.
iain331081
Actually - don't look at this yet except maybe for the code on the page.
I've managed to overwrite every record in the table with the same values for the fields getting updated on this page, so am looking at a restoration from a backup.
Just delete line 397 and update the update record value to use the session on line 157:
$WA_where_fieldValuesStr = "".($_SESSION["SecurityAssist_UserID"]) ."";
iain331081
Thans Ray - I'm not sure that's it - its not updating the details of the user currently logged in. Have attached a revised copy of the file.
You are correct that would only update the logged in user, so that was wrong. I was assuming that was what you wanted because I didn't see a reference to $_GET['UserID'] anywhere on the page other than in that hidden field. Is it getting passed to the page?
iain331081
Hi Ray - I think I've seen where I started to go wrong with it - I want to update the User, so should have made the link to the update page end with the UserID rather than the LodgeID, then it should hopefully work.
I'll let you know.
iain331081
All fixed thank goodness - was panicking a bit when I managed to update 13,000 records with the wrong data!
Add a check to the trigger to make sure the filter field has a value to make sure that doesn't happen again.
