Can't create a data connection
Thread began 9/09/2016 8:04 pm by Jim | Last modified 12/01/2016 12:17 am by Ray Borduin | 1469 views | 7 replies |
Jim
Checked my DW site specifications several times. I get an unidentified error overtime. I have double checked the FTP connection as well as the logon info for the MySQL database. My testing server is on a remote machine.
Please post FTP information and the web site url and I can try to debug and find a solution for you.
anonymous
Fixed
I was using my server IP. When I used localhost I go it to work.
The extension works on the latest version of dreamweaver, you just have to install the "Server Behaviors and Database" plugin from the Adobe store first.
Jim
More Problems Installing
Sent a private email as well.
So,first, I am also experiencing the problem with DMX Extension manager not installing anything correctly.
I used a terminal option to install the deprecated server behavior extension and web assist. They appear to be installed, buy I can't get the model connection option under web assist to give me annoying but a dialog with a caution triangle and an ok button. And the database connection gives me an error... MySQL module not loaded or can't use the mysql_(p)connect functions.
I did al this stuff after ununtalling and reinstalling DW cc 2017.
I could really use some step by step help to get this going.
Thanks.
jim
If you post a US phone number or Skype contact information I'll call you and do screen sharing to try to get it installed properly.
Jim
Skype
See private part of message
I've sent you a skype contact request. Send me a text message from skype when you are in front of your computer tomorrow and we can look into this together.
