send email if field value is "000000000"?
Thread began 9/07/2016 5:22 am by tony | Last modified 11/17/2016 5:45 pm by Ray Borduin | 949 views | 6 replies |
tony
Hi all,
I have a form on a page where the user enter a value in a field.
I this field contains a specific string (0000000000) it will receive a specific email.
If this field contains anything else it will receive another email.
I already created an universal email behaviour on the form and it will send an email on submitting the form.
How can I do this with WA?
TIA
tony
tony
ok,
I can do something working using the "show region" behaviour.
It seems to work, but there is still a little problem.
Basically I created 2 "universal email" behaviour.
I wrapped the first "universal email" behaviour with a "show region" behaviour that show the region if a specific form field IS EQUAL to a specific string.
I wrapped the second "universal email" behaviour with a "show region" behaviour that show the region if a specific form field IS NOT EQUAL to specific string.
It seems to work.
The specific string is "0000000000" (10 zeros).
So, the first "show region" behaviour is:
if ("".((isset($_POST["seriale_reg"]))?$_POST["seriale_reg"]:"") ."" == "0000000000") { // WebAssist Show If
While the second one is:
if ("".((isset($_POST["seriale_reg"]))?$_POST["seriale_reg"]:"") ."" != "0000000000") { // WebAssist Show If
The strange thing is that if insert "0000000000000000000" (more than 10 zeros) the first condition is met and it sends the wrong email. It seems that "0000000000000000000" is considered equal to "0000000000", But is is not.
If I insert a completely different value (for example: "848484848484848") it works as expected.
How can I fix this?
TIA
Use === instead of == and !== instead of !=
The issue is that it is evaluating the string as a number and "00" is the same as "00000"... using the new syntax it will use a more strict comparison of the values.
tony
Thanks for your reply.
Now it works.
But I loose the ability to edit the seerver behaviour.
This isn't a big headache, but the server behaviour should be updated to include such options, in my opinion.
Thanks again.
tony
Yes. I'll make sure it gets added.
tony
Hi Ray,
I reopen this thread because I'm not sure it works as expected.
Is this the best method to check a form field before submitting and send a different email based on the form field entered value?
Or is there a better and safe WA method for this kind of operations?
What would be your best approach?
TIA
tony
I'm not sure if one method is better than another. I'm not exactly sure what you are doing on the site or what isn't working as expected, so it is hard for me to offer advice on an alternative technique.
