excluding certain products from delivery calculation
Thread began 9/06/2016 4:44 pm by Christopher West | Last modified 9/13/2016 6:55 pm by Ray Borduin | 1469 views | 13 replies |
Hi ok, I have set up a delivery calculation page (this page is hidden from customers as its function is to perform a recordset lookup and then create a session which is then used in the ecart object.
a sample of the code is:
$rsDeliveryCost
= new WA_MySQLi_RS("rsDeliveryCost",$ecartdb,1);
$rsDeliveryCost->setQuery("SELECT * FROM shippingcosts WHERE ShippingCostZone = ? AND ShippingCostWeightTo <= ? AND ShippingCostSize <= ?");
$rsDeliveryCost->bindParam("s""".$rsShippingZone->getColumnVal("ShippingZone")  ."""-1"); //colname
$rsDeliveryCost->bindParam("s""".$eCart->DisplayInfo("TotalWeight")  ."""-1"); //colname2
$rsDeliveryCost->bindParam("s""".$eCart->DisplayInfo("TotalSize")  ."""-1"); //colname3
$rsDeliveryCost->execute();?>
as you can see I had created some additional properties in the ecart object so that I can use.
In my products tables I have 2 fields, the first is "ProductFreeDelivery" and the second is "ProductCollectionOnly" these store a value of either "0" or "1", So any products that have a value of "0" on either of these two table fields I want to exclude them from the shipping calculation.
I assume I have 2 different options:
Option 1 - Would be to do a recordset INNER JOIN to the above code to include my Products table and then I can filter out the two table fields in the above about recordset.
Option 2 - In the eCart Object, I would create 2 new properties in the "Columns" table which would store the two table fields as mentioned. With this I can then add two new lines to the above recordset, for example:
$rsDeliveryCost->bindParam("s", "".$eCart->DisplayInfo("ProductFreeDelivery")  ."", "-1"); //colname2
$rsDeliveryCost->bindParam("s", "".$eCart->DisplayInfo("ProductCollectionOnly")  ."", "-1"); //colname3
And then use that some how to check for a value that doesnt equal "1".
Are there any other ways that are more logical?
Chris
I'd just put a weight of zero in the items that have free shipping, and then put a free row in your database for zero weight.
Hi are there any alternative solutions, Im not sure if that solution would be good for me as I am also calculating delivery based on package size (not just weight).
There are a million ways you could do it.
Maybe add a column to the cart for "ChargeShipping" and set it to 0 or 1 based on whether you charge shipping or not, then add a calculation for "ShipWeight" = [Weight] * [Quantity] * [ChargeShipping]. Then you can use the total of that column when calculating the shipping which won't include the weights of items where you don't charge shipping.
That way you could use the total of the ShipWeight column to
Hi Ray, I'm looking at a fresh approach (as before I was overthinking and confusing different approaches).
I'm almost there, I just need a little help finishing of the logic.
Here is what I have done
(1) In my products table in the database I have I have 2 fields;ProductFreeDelivery and ProductCollectionOnly (these are both tinyint value of 0 or 1)
(2) in my eCart object I have added 2 columns: ProductFreeDelivery and ProductCollectionOnly (im using Output type: Number)
(3) In my eCart object for Calculations I have included:
(A) TotalWeight = [Weight] * [Quantity] * [ProductCollectionOnly] * [ProductFreeDelivery]
(B) TotalSize = ([Width] * [Height] * [Depth]) * [Quantity] * [ProductCollectionOnly] * [ProductFreeDelivery]
(4) On my product page the Add to cart server behaviour I have matched the bindings for both ProductCollectionOnly and ProductFreeDelivery
So from the above setup the the weight is calculated with any products with a value of 1 in the products table fields.
Its a little backwards, because the logic suggests that if 1 is set for (ProductCollection or ProductFreeDelivery) in the products table then include that product in the weight/size calculation) So I would need to reverse the 0 or 1 value in my admin page when admin is setting for those. Does that make sense? I guess I should have used your naming convention that you suggested with "ChargeShipping" since then any product with value of 1 would mean charge shipping. But even though my naming convention is backwards, it still works I assume. I'm just seeing if there are any issues i haven't thought of?
Chris
Chris
It looks like that would work. Yes, that is why I suggested that particular column name originally.
Its slightly giving wrong result:
My shopping basket is displaying weight of 20kg and size of 2000cm3
in my database for shipping costs I have set a price of £50 if the weight up to is 20kg and size up to is 2000cm3
However the delivery cost result on the page shows nothing.
If I change the below code to to use >= for both ShippingCostWeightTo and ShippingCostSize then it shows £50 as the delivery cost. But that doesnt make sense, since I am saying if my database value is more than or equal to the actual shopping basket value. I thought it should have been less than or equal to?
$rsDeliveryCost
$rsDeliveryCost->setQuery("SELECT * FROM shippingcosts WHERE ShippingCostZone = ? AND ShippingCostWeightTo <= ? AND ShippingCostSize <= ? ORDER BY ShippingCost DESC");
Hi this wouldnt work as ORDER BY ShippingCost DESC "ShippingCost" doesnt exist. Would this be ShippingCostValue? I did try that but it didnt return a value on the page.
I am attaching screenshot of my table in db
Chris
Yes ORDER BY ShippingCostValue
I would think that would work. Are you sure you are setting the values correctly? Try dumping the recordset to the page and see if the values are set correctly. Also try testing the SQL query in PHPMyAdmin to make sure the results look correct to you there.
