adding subtotal to column
Thread began 9/01/2016 12:15 pm by Jamie | Last modified 9/06/2016 9:14 am by Ray Borduin | 3207 views | 11 replies |
Jamie
Hey Ray
Have got an ecart installaton which is working fine in the main, but its not adding the TotalColumn("TotalPrice") to the column OrderValueBeforeDiscount in the orders table.
Its adding it to the wa_receipt.php fine - just not sure what I need to check to get it added to the table
Cheers
It will be in the Store Cart Summary In Database server behavior on the confirm and/or pp_confirm.php page.
Jamie
ok great, have added that to the pp_confirm page. on the confirm page there was already a reference to TotalPrice (see http://prntscr.com/cd7t33 ) and have tentatively added another as not sure what to do
$WA_PP_ECO_Set_params[0][$nextIndex] = "OrderValueBeforeDiscount";
$WA_PP_ECO_Set_params[1][$nextIndex] = "".$motley->TotalPrice() ."";
cheers
That is where it is passed to paypal. You need to add it in the Store Cart Summary in Database server behavior to save it in your database properly if that was the issue.
Jamie
ok, there isnt a Store Cart Summary in Database server behaviour on the confirm.php page so should I remove what I added to it and leave it unmodified?
Just edit the Store Cart Summary in Database to save the value you want in the column you want. I'm not sure what you added, but I think that was all you had to do.
Jamie
right...what i added was in the linked screenshot (which is http://prntscr.com/cd7t33 ) - so am assuming that i remove the bit I added and leave the confirm page as is and only update the pp_confirm as thats the only one with the store cart summary on it?
They both should have store cart summary on them. Perhaps hand editing has hidden the server behavior on the confirm page.
Jamie
sorry, but cant see it on the confirm page...have attached
It looks like you may be using Express Checkout Only... in which case it wouldn't be on the confirm.php page.
