Looping insert of multiple rows
Thread began 8/30/2016 2:54 pm by LionsMane | Last modified 8/30/2016 5:21 pm by Ray Borduin | 2854 views | 8 replies |
LionsMane
I have a form with jQuery function, allowing the user to add as many rows to the form/table as they'd like. Each added row has identical fields, obviously. I'd like to use this mySQLi INSERT behavior to loop through each of the user-added rows, and store each row. Any examples out there of how I can do this?
I don't have any examples. It is something I could help with in a premier support ticket.
I think if you name your fields with brackets like: name="field1[]" then it will submit them as an array. Then you can manually wrap your insert statement with a loop around that array to do the multiple inserts.
LionsMane
Looping
Thanks Ray. Yeah, the fields in question already have IDs with the [] brackets because we're looping through the fields to assemble an HTML email that gets sent to the client. That part works great. I effectively now need to do the same thing. It's the context of how to write that in the mySQLi INSERT code that I'm unsure of. If you can throw together a few lines of example on how to setup a look with your behavior code, I can try to hack it together to do what I need. I *feel* like it'd be a real quick answer, and hard to justify the $99 for this one! Maybe I'm wrong though...
Just wrap a for loop around your insert statement like:
for ($x=0; $x<sizeof($_POST['loopedfield']); $x++) {
// mysqli insert here
Then in your insert bindings use something like:
<?php echo($_POST['loopedfield'][$x]); ?>
LionsMane
insert bindings?
Hey thanks Ray. Umm... Insert Bindings? I don't quite follow which chunk that is.. Sorry to sound dense.
I mean the bindings tab in the insert server behavior.
LionsMane
OK
I think I'm following now. Will try.
You would bind it to whatever column you want it to be inserted into on the bindings tab.
LionsMane
Got it
This is working.. thanks again
