registration page not working
Thread began 8/30/2016 8:34 am by phill401410 | Last modified 9/11/2016 7:05 pm by Ray Borduin | 3181 views | 18 replies |
phill401410
On diybyphill.com when you click on "Ready to order? Click Here" you go to product_results unless not logged in and then redirect to registration page. That is good. Unfortunately Registration page is not working. Tried adding UserAuthentication > log in user. Thanks Ray.
You are still doing the simple question validation on the page but it appears you have removed that field... try removing line 50.
Also you are redirecting after the insert. Remove the insert redirect. The redirect will take place after the login server behavior below the insert instead.
phill401410
Registration page I deleted the $WAFV_Errors for simple question.
Also deleted insert redirect:
$WA_redirectURL = "login.php?success=1";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
Added Logged in to users rule for login.php:
Allow if
<?php echo $_SESSION['SecurityAssist_UserID']; ?>
blank
Getting various errors when I try to login:
Please enter a value.
Invalid information, please check your entries and try again.
Invalid username or password
Registration completed successfully, please log in to access the site
Registration page is propagating database
Thank you.
You shouldn't be adding restrict access to the login page that redirects them to the results page if they aren't logged in. If they aren't logged in they need to access the login page in order to log in.
Your success redirect on the registration page is set to:
That is making the login page automatically show the message that the user has successfully logged in even when they haven't.
You shouldn't delete those lines from insert, you should just update the redirect to "" like:
$WA_redirectURL = "";
But now it appears you have removed the login server behavior from the registration page, so maybe you should have a redirect after insert to the login page, but it should just be:
$WA_redirectURL = "login.php";
phill401410
registration and login
I can help you get this done in a premier support ticket.
phill401410
Premium ticket
phill401410
follow up to Premium Ticket
I'm glad we were able to get it working for you. Just add a link from the success page to the downloads page. You can also add a link in your main navigation directly to that page in case they want to download a previous purchase at a later date.
phill401410
Premium Session
