multiple update entering the first value on each occasion
Thread began 8/23/2016 3:02 am by gb261593 | Last modified 8/23/2016 5:21 pm by Ray Borduin | 573 views | 4 replies |
gb261593
I am using DW4 and webassist and trying to do a multiple update. I have followed the tutorial (I think) and it seems OK but when I submit the page I just get the data from the first record in the recordset entered for all of the records.
Details - I have a table (staff) which has a field staffid and pqscore. It is the pqscore I wish to update. The values for pqscore are calculated in a recordset and they are displaying on the page correctly. However, when I click submit, the pqscore fields are updated for the correct staffid values but only with the pqscore which appears first on the list. I attach a couple of screenshots which I hope shows what I mean.
Please attach a copy of the page you are working on and I'll see if I can spot the problem.
gb261593
Thank you.
You have your field value bound to the recordset. You should be selecting the repeated field from the select list as the bound value instead of using the lightning bolt. Edit the update multiple records server behavior and update the value for the pqscore field, selecting the repeated value from the list provided.
gb261593
That worked. Very many thanks.
