New Paypal SDK
Thread began 9/04/2009 2:19 pm by danjen | Last modified 9/04/2009 5:51 pm by Jason Byrnes | 891 views | 3 replies |
danjenBeta Tester
New Paypal SDK
I searched for an update on this and couldn't find any current information. Can you tell me the status on the new SDK being released from PayPal and if there are any changes I need to make to the PowerStore for Processing with Payflow Pro?
Thanks for your help.
PayFlow Pro is only supported in eCart under the PHP server modal. The PHP server modal uses the HTTPS Interface method of processing transactions with PayFlow Pro.
PowerStore does not have PayFlow pro support. You would need to use eCart to change the payment gateway being used.
PowerStore Support s Paypal Payments Pro and Authorize.net.
danjenBeta Tester
Thanks for the reply. I have already done that and I am using Payflow Pro with Powerstore 2 and have been for several months. I also use PHP. I am just wondering if there is an update for this that I need to download. How do I know if I am using the correct SDK?
Payflow pro has two methods.
The SDK Is available for .NET and Java programing languages.
All other languages will have to use the HTTPS Interface method. there is nothing that needs to be updated for PHP, it already uses the HTTPS Interface method with PayFlow Pro.
