Insert record
Thread began 8/09/2016 5:09 pm by Mohamed | Last modified 8/14/2016 2:49 pm by Ray Borduin | 553 views | 3 replies |
Mohamed
Insert record
Hello
I used insert record at webassist Mysqli SB. and i did all steps to binding data withe phpmyadmin...
When I click on submit .. the contents of the form are cleared and nothing happens.
the code:
<?php require_once('Connections/rccon.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
<?php require_once('webassist/mysqli/queryobj.php'); ?>
$register = new WA_MySQLi_RS("register",$rccon,1);
$register->setQuery("SELECT * FROM login");
$register->execute();
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) {
$InsertQuery = new WA_MySQLi_Query($rccon);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "login";
$InsertQuery->bindColumn("username", "s", "".((isset($_POST["username"]))?$_POST["username"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("email", "s", "".((isset($_POST["email"]))?$_POST["email"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("password", "s", "".((isset($_POST["password"]))?$_POST["password"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "index.php";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
It looks like it would work. Is the submit button named "submit"? Are there any required fields other than the three you are setting?
Mohamed
Thanks it's work now..
Mohamed
just i add POST in method:
<form method="post">
then it's worked
Thank you Ray..
