insert data into DB using a form
Thread began 7/28/2016 11:58 am by Rosemary | Last modified 8/23/2016 12:23 pm by Ray Borduin | 358 views | 13 replies |
Rosemary
I've bound the form field to the database using the WebAssist. But the information does NOT go into the database. Trying to find tutorials on this site is impossible as I keep getting error 500, page not found when I click on the links.
The issue with the tutorials page has been resolved. I'd need to look at your page to see why it might not be working.
Rosemary
Inserting images into DB using a form
Thank you. I figured out how to insert text into the db using my form. Now, I was hoping to find a way to "browse" the computer to upload an image to the db, so that when the web page is constructed from info pulled from the db that images can be displayed. Do you have a video describing how to do that??
I cannot get the dynamic list to add information into the table from a drop down. I've tried every possible combination.
IF you can see the screen shot, you can see I either get the manufacturer ID to be "0" or "89". I have no idea why 89.
Rosemary
ARC_products_add.php
You can add an input type="file" field and use the upload file server behavior to upload a file to a folder on your server and then save the name of the file into your database so you can display it where you need to.
The value must be coming from the select list. I couldn't tell you where the value was coming from without being able to look at the page in a browser and getting a copy of it so I can see the source code.
Rosemary
Using Dynamic List (menu/select)
Code for attempting to add products to a DB -- Friday I was getting products to ADD, but they all had the same ID for manufacturer (89). Now...that I've messed up everything, I can't get products to add at all.
I've tested the connection to the DB, it works as I can add users and they do go into the DB, but products will not. Attached are screen shots, and code. I've tried every combination I can think of....broke phpMyAdmin.....(got that working again).
I just don't know how to get this to work. Please give advice.
Rosemary
add products using dynamic list.php
I noticed is that you have the value for man_id set to the recordset result for man_name. That would probably prevent the insert since it is setting a numeric column to a text value.
I think it should be set to the form element "select".
So this line:
$InsertQuery->bindColumn("man_id", "s", "".($rs_man->getColumnVal("man_name")) ."", "WA_DEFAULT");
should look more like:
$InsertQuery->bindColumn("man_id", "s", "".((isset($_POST["select"]))?$_POST["select"]:"") ."", "WA_DEFAULT");
Rosemary
I was so excited. I thought that was the breakthrough.
Unfortunately....it still doesn't work. SO, I tried just taking the manufacturer row out....and still didn't go into the db. I guess I should start from scratch as I obviously have mucked this up too much.
I wouldn't start from scratch.... try this:
after this line:
$InsertQuery->execute();
which is the line that tries to do the insert, add this code:
var_dump($InsertQuery);
die();
That will give you more information about the attempted insert including any errors.
Rosemary
This is the result of the var_dump:
object(WA_MySQLi_Query)#5 (19) { ["Connection"]=> object(mysqli)#1 (19) { ["affected_rows"]=> int(-1) ["client_info"]=> string(79) "mysqlnd 5.0.11-dev - 20120503 - $Id: 76b08b24596e12d4553bd41fc93cccd5bac2fe7a $" ["client_version"]=> int(50011) ["connect_errno"]=> int(0) ["connect_error"]=> NULL ["errno"]=> int(0) ["error"]=> string(0) "" ["error_list"]=> array(0) { } ["field_count"]=> int(0) ["host_info"]=> string(20) "localhost via TCP/IP" ["info"]=> NULL ["insert_id"]=> int(0) ["server_info"]=> string(6) "5.7.11" ["server_version"]=> int(50711) ["stat"]=> string(137) "Uptime: 93411 Threads: 1 Questions: 2004 Slow queries: 0 Opens: 180 Flush tables: 1 Open tables: 179 Queries per second avg: 0.021" ["sqlstate"]=> string(5) "00000" ["protocol_version"]=> int(10) ["thread_id"]=> int(284) ["warning_count"]=> int(0) } ["Statement"]=> string(231) "INSERT INTO product (man_id, prod_name, prod_details, prod_moreInfo, prod_pdf, prod_image, prod_altText, prod_image1, prod_altText1, prod_image2, prod_altText2, prod_active, timestamp) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)" ["Action"]=> string(6) "insert" ["Table"]=> string(7) "product" ["Filter"]=> string(0) "" ["SaveAs"]=> string(0) "" ["ParamTypes"]=> array(13) { [0]=> string(1) "s" [1]=> string(1) "s" [2]=> string(1) "s" [3]=> string(1) "s" [4]=> string(1) "s" [5]=> string(1) "s" [6]=> string(1) "s" [7]=> string(1) "s" [8]=> string(1) "s" [9]=> string(1) "s" [10]=> string(1) "s" [11]=> string(1) "s" [12]=> string(1) "s" } ["ParamColumns"]=> array(13) { [0]=> array(2) { [0]=> string(6) "man_id" [1]=> bool(false) } [1]=> array(2) { [0]=> string(9) "prod_name" [1]=> bool(false) } [2]=> array(2) { [0]=> string(12) "prod_details" [1]=> bool(false) } [3]=> array(2) { [0]=> string(13) "prod_moreInfo" [1]=> bool(false) } [4]=> array(2) { [0]=> string(8) "prod_pdf" [1]=> bool(false) } [5]=> array(2) { [0]=> string(10) "prod_image" [1]=> bool(false) } [6]=> array(2) { [0]=> string(12) "prod_altText" [1]=> bool(false) } [7]=> array(2) { [0]=> string(11) "prod_image1" [1]=> bool(false) } [8]=> array(2) { [0]=> string(13) "prod_altText1" [1]=> bool(false) } [9]=> array(2) { [0]=> string(11) "prod_image2" [1]=> bool(false) } [10]=> array(2) { [0]=> string(13) "prod_altText2" [1]=> bool(false) } [11]=> array(2) { [0]=> string(11) "prod_active" [1]=> bool(false) } [12]=> array(2) { [0]=> string(9) "timestamp" [1]=> bool(false) } } ["ParamValues"]=> array(13) { [0]=> string(2) "89" [1]=> string(7) "testing" [2]=> string(16) "Testing Var_dump" [3]=> string(15) "additional info" [4]=> string(27) "Would like a hyperlink here" [5]=> string(34) "would like to select an image here" [6]=> string(13) "alt text test" [7]=> string(16) "additional image" [8]=> string(15) "alt text test 1" [9]=> string(13) "another image" [10]=> string(15) "alt text test 2" [11]=> string(1) "n" [12]=> string(19) "2016-08-02 18:29:05" } ["FilterValues"]=> array(0) { } ["AffectedRows"]=> int(-1) ["InsertID"]=> int(0) ["NumRows"]=> int(0) ["ParamCount"]=> int(13) ["FieldCount"]=> int(0) ["Error"]=> string(62) "Incorrect integer value: 'n' for column 'prod_active' at row 1" ["ErrorNo"]=> int(1366) ["ID"]=> int(3) ["Debug"]=> bool(false) }
I think this means I need to find a LOT more tutorials to watch.
The key is the error at the bottom:
So that means you are trying to use 'y' and 'n' for the prod_active field, but it should be set to 0 or 1
