double opt in hit a brick wall.....
Thread began 7/21/2016 8:14 am by Jamie | Last modified 7/25/2016 4:57 pm by Ray Borduin | 717 views | 7 replies |
Jamie
Hey Ray
Just been going through the double opt in tutorial and hit a couple of snags (the last of which has stopped me in my tracks). Am not sure if its because I made the rsVerify recordset using mysqli rather than mysql but here goes:
First one:
Last bit of this section this section, 'Reset the user's session variable to verified status' - when I get to step 3, 'rsVerify is not empty' is not an option in the drop down
Second one:
Got through to this section I get to step 4 and clickin on the + does nothing at all
Have attached the user-confirm and login pages if that helps.
Jamie
You can trigger off of the ->TotalRows property of the MySQLi recordset to see if it is empty. It will have to be entered manually.
You don't need to use a plus button to add session variable values in the MySQLi version, just specify a session variable name for that field.
Jamie
ok, thanks - thats got me through that bit.
like this?
@session_start();
if(($rsVerify -> TotalRows != "")) {
$_SESSION["emailVerified"] = "1";
Now in this section am at line 67 and when I click the lightning bolt, there doestn seem to be any Recordset (SecurityAssistusers) to select from... have attached screenshot
@session_start();
if($rsVerify->TotalRows) {
The binding might not be there on the email page... get the correct syntax from the page that you have applied the email server behavior on directly and copy and paste it to the email body.
Jamie
Ok thanks to both answers.
I have it all uploaded now. Few things (sorry for the list)
  1. on registration page, it has an input field for UserGroupID which is required...is this value needed and if so what for?
  2. shouldnt the passwords be hashed? if so, how do you go about doing that?
  3. how would I go about setting it so that once the password is verified, my client is notified that this has happened and then has to accept (or not) and make the user live?
  4. I couldnt find any reference to logout so not sure how to accomplish that?
  5. when going to userupdate.php
    a) the page doesnt show and b) it empties the row in the db for that logged in user
  6. the verification email is sent through, but when clicked on and going through to the user-confirm.php page i get this error:
Notice: Undefined variable: rsVerify in /home/motle7bk/public_html/clients/xxxx/user-confirm.php on line 11
Notice: Trying to get property of non-object in /home/motle7bk/public_html/clients/xxxx/user-confirm.php on line 11
Notice: Undefined variable: PowerCMSConnection in /home/motle7bk/public_html/clients/xxxx/user-confirm.php on line 80
Notice: Undefined variable: database_PowerCMSConnection in /home/motle7bk/public_html/clients/xxxx/user-confirm.php on line 102
Warning: mysql_select_db() expects parameter 2 to be resource, null given in /home/motle7bk/public_html/clients/xxxx/user-confirm.php on line 103
Warning: mysql_query() expects parameter 2 to be resource, null given in /home/motle7bk/public_html/clients/xxxx/user-confirm.php on line 108
(page attached)
many thanks
Jamie
1) It isn't necessary
2) You can hash the password when you enter it on the insert
3) Have another email go to the admin on the verify page and then include a link to the admin user update page where they can actually manually update the verified field to allow access.
4) Just add a link to a logout page with the logout user server behavior applied before page load
5) Change your page update trigger to use the form submit or button press.
6) There is a reference to a recordset on line 11 but that recordset isn't created until line 76... you will have to move the save session code down below the recordset.
It looks like you still have standard mySQL update server behaviors, not mySQLi... but the connection include file isn't on the page. You will have to add a reference to the PowerCMSConnection include to the page probably just below the DBConnection file on line 6.
Jamie
Thanks re all of that. Will look at 2) and 3) in the morning with a fresh head!
quick q in the meantime, if you select Remember my information or Log me in automatically on login, how long does the session/cookie last for and can I force it to unset?
There are going to be set cookie server behaviors on the top of the page that saves the cookies and sets the time. You can unset them by setting them to blank values or setting them to expire in the past on another page.
