Dreamweaver No Tables Visible
Thread began 7/08/2016 11:14 am by Joseph | Last modified 7/16/2017 4:02 pm by Ray Borduin | 1517 views | 3 replies |
Joseph
I am able to add the data connection in Dreamweaver for my database. At the end of that step, the window pops up where it shows the tables and views and my database for the modeling. When I try to create a record set, the data connection is there but no tables or views show up in my database.
It should be using the same logic, so I can't imagine how that would happen. If you give me a US phone number or Skype contact information I can set up a screen sharing session to look into it with you.
Don
I am encountering this same issue. I have installed the Webassist Server Behaviors on my 2 development machines. The tables show in the Query Builder on one computer but not the other. On the Recordset panel, the tables show up on both computers.
But I cannot build a SQL statement dynamically by clicking on the SELECT button on the Recordset panel. Should that work also?
Thanks.
The latest version of Dreamweaver broke the build SQL statement logic when using the "SELECT" and "WHERE" buttons... that is a known issue that either Adobe will fix or we will have to rewrite in a future version.
If something works on one machine and not the other it is probably a difference in the Site definition for the testing server. That is the information Dreamweaver uses to connect to the database and since the pages are presumably the same it is the likely location for the different setting causing the different experience.
