Understanding SSL Protection Scripts for PowerStore
Thread began 7/08/2016 9:53 am by mrobben375515 | Last modified 7/12/2016 2:16 pm by Ray Borduin | 392 views | 1 replies |
mrobben375515
I have a SSL certificate. I want to make sure I the site is actually protected correctly. I added the following code to the php pages I want to be protected:
<?php if((!(isset($_SERVER['HTTPS']))) || ($_SERVER['HTTPS'] == "") || ($_SERVER['HTTPS'] == "off"))header("Location: https://" . $_SERVER['HTTP_HOST'] . $_SERVER['PHP_SELF']); ?>
In my URL, I do see https://www.mydomain.com/ This is the only thing I have done. Should I be doing anything else, ie> add anything to the DNS manager?
I also see that you have recommended editing the .htaccess file to something like below. Is this necessary to do also?
RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://www.example.com/$1 [R,L]
Only one or the other is necessary. Once you see https:// in the url it is working.
The .htaccess solution is the cleaner of the two.
