exporting all fields
Thread began 7/06/2016 5:57 am by Christopher West | Last modified 7/06/2016 8:25 am by Ray Borduin | 224 views | 1 replies |
Hi, I wanted to find out, from the below code (which works perfectly for 1 fieldname) How can I modify it so that it exports ALL fields in a table? the code line I am referring to is
$row = array($rows->getColumnVal("ProductSKU"));
So I need to edit the above so that it will export all the fields columns.
<?php require_once('../Connections/ecartdb.php'); ?>
require_once('../webassist/mysqli/rsobj.php'); ?>
header
('Content-Type: text/csv; charset=utf-8');
header('Content-Disposition: attachment; filename=files/products.csv');
$output fopen('php://output''w');
$rows = new WA_MySQLi_RS("rows",$ecartdb,0);
$rows->setQuery("SELECT * FROM products Where ProductBrand='libra'");
$rows->execute();
while(!
$rows->atEnd()) {
fputcsv($output$row);
$rows->moveNext();
$rows->moveFirst(); //return RS to first record
Chris
$row = array($rows->getColumnVal("ProductSKU"), $rows->getColumnVal("NextColumn"), $rows->getColumnVal("NextColumn2"));
you can add as many columns as you want to the array comma separated.
