how to make a form field enabled only after selecting a specific value from a drop down?
Hi all,
I have a form with 2 fields.
The first one is a dropdown with a range of value coming from a recordset. The last values is OTHER.
The second field is disabled by default. But if you select OTHER from the first dropdown this field should be enabled.
Is there a way to do this easily with WA tools or have I to find a solution with jquery or javascript?
TIA
tony
