form not showing when added to template
Thread began 7/05/2016 12:55 pm by software.current355386 | Last modified 7/06/2016 11:11 am by Ray Borduin | 45 views | 2 replies |
generated form using form builder within a page generated from a framework theme, nothing shows. (step 1)
to make sure every thing ok, generated form within normal blank page, all ok, (step 2)
copied/renamed file from (step1) still the same (step 3)
swapped the include around (cms /sb) still no joy. (step 3))
added php error handling none reported
keep getting message, click ok/press esc se attachment
any ideas
file /site details in PM
To fix the error, try deleting your winfilecache .dat file from your users configuration folder while Dreamweaver is closed.
I can't imaging why the form isn't displaying on your page, but if it works when you apply it to a different page, then try adding it to your existing page as a framework builder plugin and then it should work.
cache delete - no more errors
used plugin minor tweaks required the wise success
will keep you posted
