Cookie, show region if value is... not works first load page in the browser.
Thread began 6/30/2016 3:49 am by Mike | Last modified 6/30/2016 3:03 pm by Ray Borduin | 476 views | 4 replies |
Mike
Hello,
I'm using a cookie value to view a region in a web page.
This is the code generated with "Utilities, Show Region Utility" from latest version of DataBridge:
if ("".((isset($_COOKIE["product"]))?$_COOKIE["product"]:"") ."" == "nameproduct") {
<p>test</p>
The behavior is:
If the cookie "product" has value "nameproduct", show "<p>test</p>".
The problem is that works good only after two refresh in the page.
Indeed, if the user open the page the first time (or close and re-open the browser) the "show region" not works.
Any ideas to resolve this issue?
Thanks,
Michele
Please attach a copy of the page and I'll see if I can spot the problem.
Mike
Hi Ray,
I've attached a copy of the page.
Thanks,
Michele
You are setting the cookie on the client which occurs after the page loads and the server code has run once. Since it appears you need to use javascript to check the country, you would have to also use javascript instead of php to hide or show the content on this page. Something like:
<body>
<div id="hideorshow" style="display:none;">
<p>test</p>
</div>
<script>
if (geoplugin_countryName() == 'Italy') {
document.cookie = "country=italy";
document.getElementById().style.display = "block";
} else {
document.cookie = "country=other";
</script>
</body>
On future pages, after the cookie has been set, you can use the php method to hide or show contents.
Mike
Great!
Thanks Ray!
