DB Results Container too small
Used DA to create this Locations page. The Container on the right displays 9 Locations but there are actually 11 in the DB. Something in the CSS is constricting the Container Height and cutting off the bottom 2 in the Alphabetical list of locations. I know this is the case because I deleted 2 locations that do currently appear and then the 2 truncated/cutoff locations reappeared. I put the 2 deletions back and then locations 10 and 11 disappeared again. I just couldn't see where to make the CSS fix. Would really appreciate any suggestion. The page in question is at http://www.schofieldstone.com/locations.php and file is attached
