Can WebAssist Dreamweaver extensions be installed with CreativeCloud desktop?
Dreamweaver CC has deprecated ExtensionManager in favor of CreativeCloud desktop. Can WebAssist Dreamweaver extensions be installed with CreativeCloud desktop?
You can install extensions using the command line by following these instructions: https://helpx.adobe.com/dreamweaver/using/extensions.html#main-pars_header_1
Or, probably the easiest alternative to the extension manager is to use the free third party extension manager found here: http://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
