Installation Wizard states session management problem, is there any more detailed info to help point out the problem?
Thread began 6/09/2016 2:26 pm by darryl394578 | Last modified 6/09/2016 4:55 pm by Ray Borduin | 93 views | 2 replies |
darryl394578
The installation wizard ran fine, except it states there is a session management problem. I have contacted the hosting company but had little information to give them except for that I had a session management error. I included a screen capture so they can see the wizard results screen. Is there any further direction I can give them to help solve the issue? I clicked on the PHP manual link, but that didn't help identify which of the hundred session codes are giving me the problem.
It usually means the php.ini setting for session_save_path is pointing to a folder that doesn't exist or doesn't have proper permissions.
If you create two pages... the first one with this code:
@session_start();
$_SESSION['test'] = "works";
and the second with:
@session_start();
die(
$_SESSION['test']);
Then visit both pages... the second page should display the value "works"... if it doesn't there is some sort of session management problem, most likely the session_save_path issue.
darryl394578
If I did it correctly, the second file did not display "works," nor did the first one. I haven't gotten a response from the hosting company, yet. I'll give them this additional info and hopefully they will help me.Thank you for the response.
