SUM() Function Disregards Date-Range Selected in the Search Form
Thread began 5/23/2016 7:03 am by salaroche | Last modified 5/25/2016 1:25 pm by Ray Borduin | 665 views | 6 replies |
salaroche
Hi:
I have a WADA Search/Results sequence designed to show the SUM() of the NUMERIC values stored in five different fields in a DB table.
The problem is the sums are always the same, regardless of the date-range selected in the Search form. What am I NOT doing right?
Please see private message below
Your search trigger was set to use the form button named "Submit" and you are using an image and javascript to submit the form not the button. I updated the trigger to look for the first date range field and that appears to have corrected the problem.
salaroche
Ray:
Thank you for making the update. A little problem now may be the need to enter a date in the "From" field. Anyway to make the image the trigger?
No... but you could add a hidden form element to the form and use that as a trigger since it will always be present.
salaroche
Ray:
OK. Let's say I add a hidden form element "trigg" to the form, how would the syntax for the Trigger field look like? Right now it looks like this: isset($_GET["S_Date7"]) && $_GET["S_Date7"]
isset($_GET["trigg"])
salaroche
Ray:
I had tried that on the local server but it disregards any date-ranges and only gives the sum for ALL entries. No problem, though, I think it's OK with S_Date7 as the trigger.
Thank you for your attention and have a good one
