Syntax for SUM() Functions
Thread began 5/19/2016 4:02 am by salaroche | Last modified 5/20/2016 2:09 am by Ray Borduin | 615 views | 4 replies |
salaroche
Hi:
I have a WADA results page with the following SELECT statement:
SELECT *
FROM pslip
WHERE username = colname
The table “pslip” includes the following columns: mmk, usdCash, overseas, retain and hold.
Now I would like to add a SUM() function for each of those columns to show the different totals pertaining to that particular user (colname).
Where should I enter the SUM() statements? Before or after the WHERE username = colname code? What would be the right syntax? I have tried a couple of ways but I always get syntax error messages.
Thank you for your attention
SELECT *, SUM(mmk) AS mmkSum, SUM(usdCash) AS usdCashSum, SUM(overseas) AS overseasSum, SUM(retain) AS retainSUM, SUM(hold) AS holdSUM
FROM pslip
GROUP BY username
salaroche
OK. Thank you much Ray, it works. Just one more question, the columns in question are varchar type. It seems that the SUM() function only adds the numeric values in it and disregards the text ones. Is that correct?
I'm not sure. I'd do a google search or experiment to see. I'd probably use CAST or something to convert it to an integer before the SUM.
salaroche
Ray:
According to some tests I've made, SUM() does disregard the text characters in the varchar column, but I'll test some more and do some googling too.
Thank you for your attention.
