Jason Byrnes : I copied and paste wa.database.jsp folder on the shared folder but it doesn't work. I use Macromedia Dreamweaver 8, Vertrigo Server on the same PC PHP I want to connect my index page with MySQL from dreamweaver by using Database ta
Thread began 5/10/2016 5:11 am by anonymous | Last modified 5/10/2016 9:43 am by Ray Borduin | 714 views | 1 replies |
anonymous
Jason Byrnes : I copied and paste wa.database.jsp folder on the shared folder but it doesn't work. I use Macromedia Dreamweaver 8, Vertrigo Server on the same PC PHP I want to connect my index page with MySQL from dreamweaver by using Database tab (Wi
I use Macromedia Dreamweaver 8, Vertrigo Server on the same PC PHP I want to connect my index page with MySQL from dreamweaver by using Database tab (Windows ->Database). It have 4 steps, from step 1 to 3 it works but on the 4th step (create a Connection by clicking on + button above) , then click on the + button and click on MySQL Connection it give MySQL dialogue box I fill the information and I try to select database it says:- HTTP Error Code 404 File Not Found. Here are some possible reasons for the problem: 1) There is no testing server running on the server machine. 2) The testing server specified for this site does not map to the http://localhost/_mmServerScripts/MMHTTPDB.php URL. Verify that URL Prefix maps to the root of the site. If you can please solve it!! but in our folder shows _mmServerScripts folder and inside this folder MMHTTPDB.php is shown. I can't solve this problem please help!!!!! God bless you!!
This means your site definition has issues most likely with the url specified in the testing server section, or you don't have a local testing server like MAMP or WAMP installed. Can you browse one of your pages using the http://localhost url?
