Nesting
Hi Ray,
How would I go about nesting one mysqli recordset within another.
I'm trying to create an xml file that when it reaches a certain tag, all the images are included in a child tag
Cheers
Norman
Hi Ray,
Cheers
Norman
Place one right after the other on the page and then copy/paste to nest them inside each other. You will probably want to move the nested recordset inside the outer repeated region manually as well.
