Warning: date(): it is not safe.........
I had to move one of my sites. Everything went smoothly except for this error:
Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /home/administratorhc/public_html/CMS/images/installed.png on line 2
site: heritagecircle.org
heritagecircle.org/index-hold.php
I can, of course, turn off error reporting for this but would rather find and nuke the error, can you assist?
also getting this error in heritagecircle.org/CMS:
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/administratorhc/public_html/CMS/images/installed.png:2) in /home/administratorhc/public_html/CMS/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: Cannot modify header information - headers already sent by (output started at /home/administratorhc/public_html/CMS/images/installed.png:2) in /home/administratorhc/public_html/CMS/admin_cms/users_login.php on line 45
Warning: Cannot modify header information - headers already sent by (output started at /home/administratorhc/public_html/CMS/images/installed.png:2) in /home/administratorhc/public_html/CMS/admin_cms/users_login.php on line 48
