Multiple Records are not added.
Thread began 5/04/2016 8:48 am by Kumel | Last modified 5/05/2016 1:31 pm by Ray Borduin | 261 views | 4 replies |
Kumel
I have a page where multiple records needs to be added but it is not adding multiple records. I tried multiple changes yet not able to fix it.
Page Attached.
Following code for inserting data:
// WA DataAssist Multiple Inserts
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) // Trigger
$WA_loopedFields = array("QuestionID", "Radio");
$WA_connection = $con1;
$WA_table = "JobAuditDetails";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "JobID|QuestionID|Checked";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL|',none,''";
$WA_insertIfNotBlank = "";
$WA_connectionDB = $database_con1;
$WA_multipleInsertCounter = 0;
while (WA_AB_checkMultiInsertLoopedFieldsExist($WA_loopedFields, $WA_multipleInsertCounter)) {
if ($WA_insertIfNotBlank == "" || WA_AB_checkLoopedFieldsNotBlank(array($WA_insertIfNotBlank), $WA_multipleInsertCounter)) {
$WA_fieldValuesStr = "".((isset($_POST["ID"]))?$_POST["ID"]:"") ."" . $WA_AB_Split . "".WA_AB_getLoopedFieldValue("QuestionID", $WA_multipleInsertCounter) ."" . $WA_AB_Split . "".WA_AB_getLoopedFieldValue("Radio", $WA_multipleInsertCounter) ."";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$WA_multipleInsertCounter++;
if ($WA_redirectURL != "") {
Page screenshot also attached.
The code looks like it would work to me. Does the other insert and update code work correctly?
If you post a URL, steps to reproduce, and give me FTP access I can debug it and try to figure it out.
Kumel
Others are working fine.
PM*
The multiple insert server behavior is supposed to create a hidden field based on the name of one of your repeated fields. However the hidden field on your page was named starting with "LockOutChecked" even though that wasn't a repeated form field on the page. My guess is that you renamed fields or removed them at some point (maybe moved from a checkbox to radio buttons) and didn't rename the hidden field properly.
I renamed it to start with the name of the other repeated field on your page: "QuestionID", and that appears to have solved the problem.
Kumel
yes i had made some modifications. Well thanks.
