cannot see mysqli server behaviour
mysqli server behaviours seems installed, but it's not showing up.
You need to also install the Deprecated Server Behaviors extension from the Adobe plugins store.
Old deprecated server behaviour was already there when I reloaded DW cc2015, I removed Webassist Mysqli server behaviour and then reloaded the app It worked!. Somehow Webassist installer didn't kick in previously. I am using php7 server on this computer in order to rewrite php code in php7 I hope everything will work ok with php7 server. Thank you anyway for help.
