Delete from Details page
Thread began 5/02/2016 1:32 pm by bjgarner241692 | Last modified 5/04/2016 11:39 am by Ray Borduin | 762 views | 7 replies |
bjgarner241692
My record includes a file, which needs to be deleted when the file is deleted. I have added the delete behaviour, made sure it was after the recordset and tried specifying the image from a hidden field rather than from the recordset. I have also tried various triggers. When I click Delete, it deletes the record, but not the file.
Access in PM
bjgarner241692
access in PM
Your file delete is below the recordset delete, which includes a redirect that will take you off the page before the file delete can run.
Try moving lines 83-89 up above line 52
bjgarner241692
Tried that earlier as well, but I get this error if it is anywhere but at the end.
Warning: unlink(C:\Inetpub\......\assets) [function.unlink]: Permission denied in C:\Inetpub\...\webassist\file_manipulation\helperphp.php on line 779
Warning: Cannot modify header information - headers already sent by (output started at C:\Inetpub\....\webassist\file_manipulation\helperphp.php:779) in C:\Inetpub\....\_admin\opportunities_detail.php on line 86
It is not a permissions issue. If I can upload, I can delete.
The delete button uses a different form, which didn't include the hidden field with the file name. I added the hidden field to the delete form and it is working now.
bjgarner241692
Thank you. I did not notice the second form. It works fine now.
I just noticed however that the Remember Me option is not working at all. My browser does not call up the password either. Is there something in the Security Wizard that is blocking this?
I just tried and the remember me and autologin worked for me. Perhaps it is an issue with the cookie settings on your computer.
bjgarner241692
Likely. Thank you for checking.
