Pagination doesn't work for my DataAssist pages
Thread began 4/28/2016 11:38 am by Yvonne | Last modified 6/24/2016 12:41 pm by Ray Borduin | 1409 views | 7 replies |
Yvonne
I have used DataAssist to build search, update, detail, results pages (php) and the search works but pagination does not. When clicking the next page button the results page refreshes but there are not results found, 1st page is 1-20 of 71 records, pages 2 and 3 show now records [cap_results3.php?pageNum_WADAcapturepages=2&totalRows_WADAcapturepages=0&userName=&userEmail=&userBrokerid=&Search=Search]. Please let me know what needs to be done to get pagination working.
cap_results3.php
I'd have to debug it, but maybe the repeated recordset code is causing issues.
Try deleting the code on rows 160-210 and see if that fixes it. If not, please post a url where I can see the page and FTP access if possible and I'll debug it directly.
Yvonne
Reply in PM
The code that builds the next page link was too high on the page... it needs to be below the recordset, so I moved it to lines 167-183. The page appears to be working now. Just get the version I uploaded.
Yvonne
That is awesome, thanks!!
Yvonne
I had to rebuild the pages, we added new fields, and the same problem cropped up again. I cannot see the code you moved in the previous file in the current results page. I cannot see where the function executes prior to the record set.
Move lines 53-69 down below line 183... just before the <!doctype html>
Yvonne
Thanks, works like a charm. I really appreciate your help.
