My website was restored by the hosting provider. Now the PowerCMS Builder is not working properly, I can't login, why?
Thread began 4/27/2016 7:51 am by info334556 | Last modified 4/28/2016 1:50 pm by Ray Borduin | 94 views | 4 replies |
info334556
I can't seem to get in with the FTP credentials you provided. What server name should I use? Can you test and verify it works for you and I'll try again.
Most likely session variables aren't being stored and are not configured properly... but I can't be sure without debugging directly through FTP.
I was able to log in. What happens when you try?
info334556
It was because the hosting provider switch the PHP to 5.4, I don't know why, from 5.8.
If you have the problem again I can debug it. I doubt it was simply the php version but they probably had different configuration settings in the other version that somehow caused it.
