customizes where
Thread began 4/22/2016 5:54 am by mbunal | Last modified 4/26/2016 11:27 am by Ray Borduin | 528 views | 2 replies |
mbunal
customizes where
i need that:
if admin
$WHERE = "1=1"
else
$WHERE = "client=col_client"
rs_query = "select * from table where $WHERE"
i run similiar code but recordset vanish from binding panel. i dont want it vanish. is it possible?
No, it will disappear from bindings.
A work around would be to add the recorsdet code in its original form like:
// your original recordset code here
That way you can have the recordset in a readable format for Dreamweaver but the code will be ignored since it is commented out. Then you can add your copy of the recordset with the updated code below. Yours will run, but the bindings will be created from the commented out one.
mbunal
thank you very much for this usefull info
