Error on File manager start
Thread began 4/17/2016 9:41 pm by Blikbrein | Last modified 4/22/2016 10:07 am by Ray Borduin | 1253 views | 6 replies |
Blikbrein
I know this is an ancient product, but I have a client that could really use it well if it works properly.
I've copied over the latest KFM files found in PowerCMS to see if this fixes the problem, but no luck so far. I get the following error when trying to use the file manager:
Warning: require_once(/home/mansudevvirtualc/public_html/PowerMessenger/webassist/kfm/classes/MDB2_Driver_Datatype_Common.php): failed to open stream: No such file or directory in /home/mansudevvirtualc/public_html/PowerMessenger/webassist/kfm/initialise.php on line 19
Please help
If you give me FTP access I can try to debug it for you. I'm not sure what would cause this error.
Blikbrein
See PM - thanks!
What are the steps to reproduce the error? What page should I go to? What should I click on? Accessing the FileManager directly seems to work, so it must be something on the page that is using it.
Blikbrein
Login to Admin(see pm), go to mailings and open the first one. use file insert or right click on image to edit and the click browse server. ERROR. Thanks for taking a look at this.
I just downloaded the version from your powercms installation and overwrote this one and it seems to have done the trick.
Blikbrein
Thank you. I thought I did that, but maybe it was older files. Appreciate your help.
