file name change
Thread began 4/04/2016 9:10 pm by Kumel | Last modified 4/06/2016 1:28 pm by Ray Borduin | 344 views | 10 replies |
Kumel
file name change
when i upload pdf file with file named: '86'-LotoManager.pdf in db its the same but folder where file is located the file name is : \'86\'-LotoManager.pdf
Seems like apostrophe is causing problem. How can this be solved? Cos link gets broken.
blueprints.php
Make sure magic_quotes_gpc is turned off on the server. Having that turned on can cause issues with quotes.
Kumel
whats that & how do we do that?
You can fix it in the php.ini file. If you check the php_info() value it should show you the setting to confirm if that is the issue.
Kumel
this is on my local server.
Well then you can change the setting in your local php.ini file: http://php.net/manual/en/security.magicquotes.disabling.php
Kumel
Well i uploaded onto the server to test them. i added following in php.ini :
php_flag magic_quotes_gpc off
The file name is yet saved in same format as earlier.
By the way php.ini gotto be on same folder? or main folder? cause once after customer login's he taken to different folder like en/
Example: www.domain.com/en/blueprint.php
blueprint.php is in a folder called 'en'. So where should php.ini be placed?
If you add this to the top of any php page:
phpinfo();
it will tell you all of the settings and the location of your php.ini file.... It won't be in the actual web site root it will be in the php installation folder.
Kumel
adding this <?php
phpinfo();
?> provide list.. what field required for you to know?
search the list for the location of the loaded php.ini file and search for the setting for magic_quotes_gpc.
I don't need them, you do in order to update the setting if it is wrong.
