Using Update Behavior Custom PHP Data Edits
Thread began 4/01/2016 2:10 pm by TonyE | Last modified 4/05/2016 4:53 pm by Ray Borduin | 497 views | 4 replies |
TonyE
I created an update behavior to update my database and moved it further down in my program and wrapped it in my custom PHP code to perform data edits. Updates to my database worked fine at first using the update behavior and my PHP code. However, when I used WebAssist to add several more fields to update, it deleted my custom PHP code and moved the update behavior back to the beginning of the program. I can't find anywhere in WebAssist documentation or tutorials that illustrate how to do use custom PHP eidts and only do the update if it passes all custom PHP edits.
It shouldn't mess with your updates as long as you add them in their own php code chunks... so it would look like:
//your custom code
// code produced by the Server behavior
// more custom code
as long as you add them to their own code section they shouldn't be messed with.
(btw I noticed you have some blank lines in your code between ?> and <?php on the top of the page... that can cause issues in php and the blank lines should be removed)
TonyE
Ray, thanks for your quick response. I understand what you're saying in your reply. What I don't understand is how do I make the update behavior conditional based upon the form fields passing my PHP edits? I thought enclosing the update behavior within an IF statement would work. But, you're saying the update behavior has to be kept in it's own code chunk. Plus, when I updated the behavior it deleted my code. I'm thinking I can use a "hidden" field on the form and update it to say the edits passed or failed. Then test the "hidden" field using the Trigger feature of the update behavior. However, since the Trigger feature using the Lightning Bolt (dynamic) is not adequately explained I have no idea what to put there. Do I put an IF statement, just the "hidden" field or what? Any insight you have on using the Trigger feature would be appreciated. If none of this is viable my other option is to just create another program to do the updates when the form is properly edited. I wanted to say away from this option, if possible. The bottom line is that I don't want the update behavior executed if any field does not pass my edits.
You can still wrap it in an IF statment:
if ("this" == "that) {
TonyE
Ray, your suggestion worked fine. I had the right approach but didn't wrap the Server behavior correctly. Thank you so much!
