When my insert/update forms are submitted, back slashes are being added into my MySQL database before apostrophes and quotes. How do I stop that?
Thread began 3/27/2016 1:57 pm by John | Last modified 3/28/2016 5:58 pm by Ray Borduin | 169 views | 3 replies |
John
I've never had this issue before, so I assume it must be related to using WA MySQLi, which I started using recently. I read through the forum and found one person who said to add <?php ini_set('magic_quotes_gpc','on'); ?> to line 1 in the pages, but that didn't solve it. Interesting, there are a couple WA HTML Editor fields that are not resulting in this, but others that are, in addition to regular text box form fields that do. But I can't see anything different in any of them that would cause the different results.
Any help would be appreciated. I'm trying to get this site launched and obviously can't with this situation.
Thanks,
John
I think you want the opposite... you want magic quotes gpc turned 'off', so you would want to add <?php ini_set('magic_quotes_gpc','off'); ?> to line 1 in the pages.
Even better would be to disable it in the php.ini file.
John
I just tried adding it to line 1 with no luck. I guess I'll try to figure out how to edit my php.ini file.
John
Once I turned it off in php.ini it solved the problem. The line was commented out, so I just un-commented it.
Thanks.
