double opt in registration tutorial.
Thread began 3/21/2016 9:40 am by s.joiner74419001 | Last modified 3/22/2016 5:57 am by Ray Borduin | 219 views | 2 replies |
s.joiner74419001
I am using the double opt in registration tutorial to add a 'Verify email' function to a form submission. The problem I have is understanding the section headed - 'Create the expire used random string functionality'. It does not explain what to put in the 'Trigger' settings for the update behaviour.
Do I use the same as the previous 'Update behaviour' which uses 'URL variable = id'
Thanks in advance!
I'm not familiar enough with the tutorial... Is this on the send email page before the email is sent? If so you can use the same trigger that the email uses.
s.joiner74419001
No problem Ray, I've sussed it.
