missing pages
I'm having some problem with my site...when i upload the folder it keep telling me about some missing files
Those are note files used by dreamweaver. They shouldn't be necessary. You can just ignore that message.
Okay. Thank u. Now I have a lil problem. I don't remember my pass for my admin login. How can I find it. Or change it.
You can look in the database through your hosting control panel phpMyAdmin. It is stored in the wa_settings table.
It looks like some of the tables didn't get created during the install process. If you had this running on your localhost you could use phpMyAdmin to export your local database and then import it into the live database. Either that, or you could delete the /webassist folder on the live server and run the installer again which should create the tables for you.
thanks i did what u say and it work........now we talk about this before....i still have this mesage still coming up on my computer about some missing files......u told me to forget about the message i did but every time i upload my file from dreamweaver cc i have to keep clicking over hundred time on till it finish uploading.....this was not happing before it start after i reinstall the shapping cart......im trying to see what happen or what i did wrong
These have nothing to do with the cart. This appears to be a dreamweaver issue with the notes and synchronization files Dreamweaver uses internally. I'm not sure of the cause but I don't think it has anything to do with our software. Usually dreamweaver creates those files when you update your site definition... maybe try changing your save folder in your site definition.. then click 'ok' and save it back to the correct folder and then I think Dreamweaver would recreate those files if they are missing.
Delete the folder: /imagesadmin/.files
and update the permissions on the /imagesadmin/ folder to: 777
