I'm receiving error when attempting to finish using the Webassist plugin
Thread began 3/04/2016 2:43 pm by wyncole | Last modified 3/09/2016 10:15 am by Ray Borduin | 1370 views | 11 replies |
wyncole
I've gone through the process of using the webassist plugin "DataAssist". After building my pages and select finish I receive the attached error message. I have deleted the cache file but continue to get this message.
Thanks,
Wyn
DataAssist isn't supported for CC 2014. You would have to upgrade to DataBridge to work on that version of Dreamweaver.
wyncole
Reinstalled DataBridge but get different error message
I reinstalled DataBridge and tried to edit the search page (inside DataBridge wizard) and I received the attached error. After continued attempts,
Updated status:
Dreamweaver crashes while I am in Data Bridge - Database - selecting pages (Search,Insert,Detail...). It just dies. No error message at all.
What version of Dreamweaver are you using? If you are using CC you will have to install the Database and Server Behaviors add in from the Adobe plugin store (it is free).
wyncole
Still Having trouble with extensions
I've downloaded Dreamweaver CC 2015 as well as Data Bridge and Design Extender. I get the following message (see attachment) from Adobe extension manager when I attempt to install your plugins. and a similar one for the database extension from adobe (message for their plugin needs version 13 or greater).
I just noticed that DW is not showing up in the Extension Manager. It does show Photoshop. I see no way to add DW to the list. I would assume that it should see it without me doing anything.
Adobe has dropped support for extension manager in Dreameaver CC 2015. The best solution I've found is to use the free third party extension manager from DMXZone: http://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
@wyncole as Ray suggests, I recommend the DMXZone solution, the great thing is I have found lots of neat little free plugins on there that come in handy, so its a win win solution :)
wyncole
Ok,
Thanks,
wyncole
Ok,
Thanks, I'll download it and give it a shoot. I presume the Webassist plugins work as they have in the past?
Thanks,
Wyn
Yes
