DataAssist Results page doesn't recognize foreign key
Thread began 3/02/2016 9:02 am by tmcbinc99963 | Last modified 3/02/2016 2:53 pm by Ray Borduin | 522 views | 2 replies |
tmcbinc99963
After creating Search/Results pages using DataAssist Wizard, configuring the necessary tables/columns for a foreign key in phpmyadmin, and updating the WADA recordset for an INNER JOIN, the results still displays the ID and not the name.
In phpmyadmin, the mysql Db relation is working properly - I can hover over the FK field and it shows the name.
In DW, the recordset uses INNER JOIN and the test shows data from both tables, but still shows the FK field with the number, not the name.
Searching the forums and also online provided help in setting up phpmyadmin and INNER JOIN, but can't get the results table to show correctly.
Attached are screen shots of both recordset setup and test.
You should just be able to update the column reference on your page where it is showing the id and update it to use the column name that has the full text. It looks like your inner join is working, so you just have to make sure to display the correct column from the second table by changing the column name in the code.
tmcbinc99963
Perfect. Thanks.
