How to edit Power Store 4.54 porducts_detail.php page
I have made edits to a products_detail.php that was created using eCart6. I want to incorporate the code into PowerStore4.54's products_detail.php page. How do I do this? I am attaching both my
Updates would be made to the page: webassist/plugins/catalog/details.php
You can probably cut and paste most of the updates you made directly into that page. If you need help, this is something we could help you work in in a premium support ticket.
I was doing a clean install of PS4.5 so I used the files in PowerStore454.zip. That folder does not have a "webassist" folder. I see that folder in PowerStore454_update.zip, but the instructions for install in the PowerStore4.5 page said that was for upgrading from PS4 to PS4.5. Should I be using all the files and folders in PowerStore454_update.zip?
Once you run the installer the webassist folder will be moved from the install folder to the root.
I see it now. I had not scynced my DW since the install. Thank you.
