drop down menu only shows one option
I used the data assist pages menu /manage pages /edit as described to create drop downs for the insert and search pages. I chose the correct table, selected 'menu' chose columns, etc. I chose the same value for 'values' and for 'labels'. but the resulting drop downs only include one value, not the full choices. This is an 'enum' column; maybe this is not the right way to get a drop down. Am I doing this the right way, or in this case should i do it the way it is done on admin lines 133-138?
Also- note the way the search page looks on boats_search: larger drop downs and centered text on left compared to event_insert; the first example is more desirable. how to make these all like the boats_search example?
thanks again
